Display settings
Display settings
Display settings
Hi, how can I set the display, or colors to this?
 Thanks in advance!
gcoombridge
Presentation looks close to that but its an off-white. I think that is a custom setup - which you can make here:
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
mcgyvr
 Thanks in advance!
Can you be a bit more specific?
You just looking to change the background color in Inventor?
Or something related to the selected part edge highlights? a specific color to them or something?
Maybe just unchecking "Enable advanced highlights" from tools..application options..colors tab is what you are looking for.
When I make an assembly, or part, the colours are this:
 But I want this:
 I dont know, how can I set the colours to this. I have a Quadro M4000M.
mcgyvr
Are you ONLY talking about how your background is gray and their background is white? (if so go to tools..application options..colors tab and select "Presentation" as shown by @gcoombridge  above.
Or are you asking how to change the colors of individual parts? if so open the part and select a new color from the appearance dropdown menu in the quick access toolbar
