ok, that works - thanks. I was hoping there was a way to have it do this
automatically, it seems like it should!
Thanks again.
"MarkC-UK" wrote in message news:6306501@discussion.autodesk.com...
I think the OP is talking about a dimension in an .idw, rather than in the
part environment.
I don't think it can be done, other than RMB the dimension and click
text.... In the format text box, click the source box and bring up the
associated user parameters (so you can see the full list of parameters).
Select the correct parameter and then click in the text editor space and
manually type in the relevant parameter name. Click OK.
Then RMB the dimension again and click edit... and place a check against
'hide dimension value'. Now you'll just have an associated dimension that
just mentions the parameter and no actual value.
I know it's a big fudgearound but I can't see a cleaner way of doing it.
MarkC
