Display of threads in exporting file formats e.g. step
Message 1 of 9
I have to export 3D drawings with threads for customers who needs other file formats.than Inventors .ipt
One asked for STEP, but when I have made the export and opened it in Inventor LT 2014 to check if everything is okay the threads were missing in the file. 😞
I found a post from 10.06. 2011 about this subject, explaining that STEP format dose not carry the thread information.
It also suggest to pecify the thread size, pitch and length. (I pasted in the post for reference, see blue text below)
How can I do this on the drawing?
Is there a way to show threads in the drawing, that can be included when I export to other formats?
I guess the customer wants to insert my drawing in their own exsisting drawing, but if the part includes a thread, how can they use it if they are using another software that inventor?
Is there any of the other 3D file formats available in inventor that can show the thread type in the drawing?
Re: Exporting STEP with threads?
10-06-2011 02:32 PM in reply to: es12
es12 wrote:
I have to export the drawing to STEP for machinist that uses Solidworks.
SolidWorks does threads exactly the same way (cosmetic representation).  STEP does not carry this information.  You simply need to specify the thread size, pitch and length - your machinist should be able to figure out the rest.
Thanks in advance,
KBE
Replies (8)
Message 2 of 9
JDMather
Is there a way to show threads in the drawing, ...
KBE
You seem to be confusing the terms "parts" and "drawings".
1. Create a 2D drawing with the thread notes and send that along (as a pdf) with the STEP,
or
2. model the thread rather than use cosmetic threads.
#1 is the more usual technique.
Message 3 of 9
mcgyvr
^^^ Yep.. We do #1 for all our outside sheet metal, screw machine, etc... vendors
The ONLY reason to actually model "real" threads is for 3D printing
A step file is not a drawing, its a 3D model
Drawing = 2D
Part/model/step/iges = 3D
Message 4 of 9
HI,
Thanks for yor reply.
Yes, I see, my use of the terms "parts" and "drawing" is not consistant, sorry Smiley Wink
My question is regarding the 3D model.
I am working in inventor, but haven't tried the exporting feature untill now and thought the thread info would be included in the exported file as well.
Is best practise on this issue to deliver the STEP file accompanied by a 2D drawing (pdf) with dimensions including the thread notes?
thanks in advance,
Kbe
Message 5 of 9
mcgyvr
@Anonymous wrote:
HI,
thanks in advance,
Kbe
depends on what you are doing with the file and what information the end user needs.
But yes STEP files do NOT include thread information nor any other information besides the actual physical model.
Part finish, tolerances, thread detail, etc... are not included.
So if you are sending this to a vendor to make the part for you they will need more information than what a step file can provide which is typically done with a 2d drawing included with the step file.
The vendor may use the step file for programming the machine and the drawing for any other information thats not included in the step file.
Message 6 of 9
JDMather
@Anonymous wrote:
My question is regarding the 3D model....
Kbe
...and if all of this is in reference to threaded holes - use the Hole command with Thread option to get the correct tap-drill sized hole in your 3D Model.  I find it astonishing how many designers specify a Ø5mm hole for an M5 fastener.
Message 7 of 9
merismith
Community Visitor
Community Visitor
Can someone explain to me how to export my files to .stl that keep the threading?  I am trying to print some sample parts for student projects and we cannot get the threading to carry through.  I know it has to do with the geometry, but we haven't figured out how to get the geometry of the threads to carry into the .stl file.
HELP!!!
Message 8 of 9
JDMather
The default Thread features created by Inventor are only cosmetic representations (zoom in very very close - do you see any real cut threads?).
If you want to 3D print threads - you will have to model the physical threads.
Attach your *.ipt file here if you can't figure it out.
Message 9 of 9
graeme_robinson
Bit harsh that response, spread some positive vibes, makes for a happier day for all
I am looking into a similar proces, I have been exporting data to the customer as ipt and Iam.  Now the sutomer has solidworks and when I export the iam file the fasteners dont have any thread information.  Yes its an image, but there is a thread length,
 am getting around it by doing a pack and go of the inventor assembly i am doing, then in the pack and go doing a 0.01 mm cut to show the thread in the fasteners on the inventor part, then sending the stp file to the custmer.
Granted there are abotu 100 fasteners but on about 8 different types of fastener.
then the happy customer can see if the thread lengths are exatly what he wants,
then when the design is all good and parts in manufacture the assembly pdf can be created.
all Good!!!
