Greetings
In sketch and assembly modes, I'd like to set my default to "Display As Expression". Is there an easy way to do this?
Process:
>Tools
>Document Settings
>Units
>Display as expression
Thank you
Vince
Hi Vince,
This can be done easily by making the change in the template files. Go to your default template folder (C:\Users\Public\Documents\Autodesk\Inventor 2018\Templates\) and find the ipt template file. Open it and make the change and save.
Many thanks!
I seem to be having an issue with opening - see attached. Is there another way to access this?
Vince
As with any Inventor files, it's much better to open them from within the program. You may want to create a project file (.ipj) in the templates folder and switch to that project, then open the templates for editing. But open Inventor first, then open the files.
Sam B
Inventor Pro 2019.0.0 | Windows 7 SP1
LinkedIn
Thank you all for your assistance.
I am a simple designer and fabricator in the film & TV industry x 45 years. You are obviously technically light-years ahead of me and since I can't figure out how to change a Template ipt default to "Display as Expression" without getting a dialog message box telling me there is a problem when trying to change the Template ipt, I've contacted Autodesk directly to assist me.
Again thanks for your assistance!
Vince
