Disable or change Instance properties to Custom Properties in BOM
Hi all,
I'm using Inventor 2023 filling the manual BOM fields inside Assemblies, but I'm having some problems with custom and instance properties.
I don't need to make different properties, so I need that the properties filled in the BOM propagates to all instances of my sub assemblies (keeping a black text).
But sometimes (couldn't understand why), the field keeps Instance property only (blue text).
I've checked the sub assemblies and all are with the correct representation/model state/design view in the assembly. And all of them are with Edit Factory Scope enabled (so any changes would be in the custom properties of all instances).
When I click with right button and try change to CUSTOM, nothing happens. If I delete the values and try again from the BOM view, doesn't change and keeps with blue text.
The only solution I've found untill now is yo enter in each Sub, go to iproperties>Custom, then edit each field writing and space in the end of value, ENTER, delete the space and ENTER again, so the properties are propagated to all instances/states and in the Assembly BOM the text becomes black (considering the edit factory scope option is ON).
How can I change it to custom property and propagate to all instances directly from the Assemblies BOM ?
BOM with some custom and some instances properties:
Edit factory scope enabled for all sub assemblies:
Representation of all subs are ok inside the main assembly (I need to use the FINAL one for now):
Trying to change to CUSTOM:
Thanks!
