Disable Driven Dimension Prompt
Benjaaamin
Benjaaamin
Hi All,
Previously in versions prior to Inventor 2026 I had this prompt disabled (I use driven dimensions for cross checking) but working with 2026 it has returned and no longer have the ability to set to 'Accept' & 'Never' in the Prompts settings.
Can anyone confirm if there is a way around this or am I stuck with having to accept constantly?
jnowel
How about this option?
CCarreiras
Hi!
You can change the settings here:
CCarreiras
CGBenner
@CCarreiras
Hi, is that in IV 2026?  Is it one of the "dot" releases? (ex. 2026.2)
Chris Benner
Benjaaamin
You are a legend @jnowel !! I knew it was somewhere but thought it was in the prompts
Thank you so much!
CCarreiras
@CGBenner wrote:
@CCarreiras
Yes, version 2026.2
CCarreiras
