DIRECT EDIT
DIRECT EDIT
AnthonyHarris90842
DIRECT EDIT
AnthonyHarris90842
I am using direct edit to move a solid which is fine.
I then want to move a surface and I cant find a way to do this as even if you select faces it wont select a surface.
See image
CCarreiras
I believe Direct tool only works in solid faces.
Tip: You can use other tools to edit the surface... Use Thickness tool (surface mode) to offset the surface, or extend the surface, etc.
CCarreiras
JDMather
For Surface Body...
It says Solid Body in the tool tip - but it will also move surface bodies.
AnthonyHarris90842
Hi JD
Thank you very much
But you cant scale like you do in direct edit.
JDMather
I don’t see that in your original problem statement.
To scale used Derived Component. 😎
