DIMENSIONS ON PIPING ISOMETRIC DRAWING ARE NOT ALIGNED
mfurches
mfurches
FOR SOME REASON ALL OF A SUDDEN MY DIMENSIONS ARE NOT ALIGNING AS THEY SHOULD FROM ROUTE CENTERLINES. THEY ARE BEING CREATED MORE AS A PROJECTED DIMENSION RATHER THAN A TRUE DIMENSION.
THE FIRST PICTURE SHOWS HOW MY DIMENSIONS TYPICALLY LOOK. THE SECOND PICTURE IS WHAT I AM GETTING NOW.
Sergio.D.Suárez
hi, I can not distinguish the image. If you say that the dimension seems projected, look if you can right click and select the plane of the sheet1.jpg
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
mfurches
It does not appear that i can select the plane of the sheet.
Sergio.D.Suárez
Here I show you an example, I do not know if it applies to your problem
Mechanical Designer
mfurches
I think my issue has something to do with a setting. Isometric dimensions work fine in one drawing and in another made using a different template they don't work correctly.
johnsonshiue
Hi! Is the dimension type on second drawing view set to True as opposed to Projected? Right-click on the view -> General Dimension Type -> select Projected.
BTW, please avoid typing in all-cap letter. It is like yelling at people.
Many thanks!
Software Test Engineer
