Dimensions Flip on export to 3D PDF
Light_Guy
Light_Guy
So I finally got update 2 installed and now we are starting to see what we can do with the 3D annotations. One thing I noticed today was that upon exporting to 3D PDF, some of my dimensions are now backwards. Anyone else had this issue?
Paul Hamor
Senior Designer/CAD Manager/Data Manager
"Always Good Ships!"
johnsonshiue
Hi! This is unfortunately a limitation in 3D PDF. Inventor has the ability to flip direction based on view direction. But, PDF does not have the same ability. The dimension is just a stale object in the space. This particular case seems that the 82 dimension was created in an opposite view direction. Could you recreate the 3D dimension in the desirable direction before you export it to 3D PDF?
Many thanks!
Software Test Engineer
