Dimension orientation
Ktelang
Ktelang
Hello Everybody,
I have attached a part file and drawing of the same.
The 1'-8" value is above the dim line can I get it below the
dim line as if mirrored about the  dimension line.
Please find the images attached for futher clarity
Is there any simple option which I am missing
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
mercerc
            I’ve looked at the file and the dimension styles and the text (unlike just text) can’t be rotated. I’ve created a style of text that is rotated 180 degrees and as text goes it works fine. If I set the text as the text that the dimension style should use it rotates it back to 0 degrees. If you edit the text in the dimension style you will see the text option of rotation is grayed out.
Charlie M
Inventor Product Support Specialist
Ktelang
Thanks for the reply
I tried doing what you tried to do.
Its not working for me.
Please correct me if I am wrong
The intent of your post says that we can't achieve that kinda
rotation in the text, correct?
Thanks again
mercerc
You're correct we can't do the rotation in the dimension text
Charlie M
