Diffrent BOM list at diffrent sheets
Hi Does any one know if i can have different BOM list at different sheets, i do have one number consisting of 4 sheets and for 2 of the sheets do i need to have BOM list, but at the one sheet do i need to hide som lines and expand som-when doing this will the other BOM list do 100% the same. Is the BOM list synchronized ? As i remember is it possible to have different BOM list at different sheets in same overall sheet ?
Xun.Zhang
How about leverage Assembly View Representation filter filter to do so? In general, you can create several design view in the assembly with the component set in proper visibility, then, create BOM for each sheet, associate with right Assembly View Representation to make different partlists.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-414E16B4-1ACB-4E17-A036-D3EAF1602567
Hope it helps!
Xun
Hi
Thanks can be a solution, but the CAD department dont use this genial function-and im just doing documentation.
But i think i will create virtuel components and add them to their 3D iam and then i think my task can be done.
Or else your solution can be next test step
