Yes, some clients can have bizarre requirements.
I am just curious - how do they handle the drawings' numbering? Say, there is an assembly with the assembly number 25-GA. It is a fairly large assembly. To document it - some extra drawing sheets are required. If all of the sheets are in one file - the file number for them will only be different by the sheet number. And the sheet number is listed separately in the TB itself. So, if an individual sheet needs to be printed out - it will have number like 25-GA_s2, for example. If the whole set of sheets is printed - it will have 25-GA file number. And in this file there will be all drawing's sheets, pertaining to the assembly.
The revision of the part/assembly is coming from Revision Number in iProperties of corresponding model. But for the description of the revision I use a sketch symbol, placed into the TB. That way if I raised the revision in the model iProperty - it will be reflected in TB. And it will alert me to copy, paste and edit previous revision sketch symbol in this TB.
To indicate the area to which revision applies - revision triangles are used. Which are too sketch symbols.
Anyway, I am not advocating you or anyone else to review one's drawing revision protocol. Yet the question about Inventor Revision table (its functionality) comes up on the forum every now and then. Which makes me wonder if the effort to use this particular function of inventor worth my time.🙂
Cheers,
Igor.
Web: www.meqc.com.au
