different results from this same simulation
Message 1 of 9
hi,
for more complicated shapes (see attachment) I get strange results... I mean it is like this:
Fixing, Moment, Material and Force are not changed during this test.
I turned on "create curved mesh elements", Run Simulation: safety factor result: 4,5
I turned off "create curved mesh elements", Run Simulation: safet factor result: 11,4
I turned on "create curved mesh elements", Run Simulation: safety factor result: 4,23
I turned off "create curved mesh elements", Run Simulation: safet factor result: 11,27
etc. values are not the same all the time! they're floating
for less complicated models values are stable
what is wrong here?
Replies (8)
Message 2 of 9
JDMather
@Anonymous wrote:
.....what is wrong here?
Probably nothing.
Are you running Convergence Analysis?
Attach your file here.
Message 3 of 9
I would assume that a slightly different mesh is created on each mesh update.
Message 4 of 9
JDMather: unfortunately this particular one can not be shared with outside world
Ps. "Covergence analysis" - which option are you writing about?
ccamara01:  I thought that algorithm is an algorithm... so you say that results depends on, hmmm, computer's mood ? 🙂
Message 5 of 9
JDMather
@Anonymous wrote:
JDMather: unfortunately this particular one cannot be shared with outside world
Ps. "Covergence analysis" - which option are you writing about..
Do you see this behavior only with this particular file?
Are you saying it can't be reproduced in a simple example file?
What book are you using to learn Inventor FEA?  Most books would cover the topics of mesh and Convergence.
Message 6 of 9
this happens only for more complex shapes
see movie attached
Message 7 of 9
JDMather
I was expecting your file so that I could demonstrate why it is happening with your file.
http://forums.autodesk.com/t5/inventor-general-discussion/easiest-way-to-learn-fea/td-p/5484707
Message 8 of 9
I'll prepare another model with the same effect soon and I'll upload it here.
Message 9 of 9
JDMather
Before you spend a lot of time on this, you might want to go through this -
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2014/inventor/md6583
especially Reconciling Differing Results video and the Handout(.pdf)
Basically it is all in the mesh and you have changed the intial condition.
Doing a Convergence Analysis should converge on "the answer".
