DIFFERENT ANGLES IN DIFFERENT VIEWS
rclement
rclement
IM TRYING TO MANIPULATE THIS DOOR HINGE
FROM 90 TO 45 .IM TRYING VIEWS BECAUSE I WANT TO USE THE SAME PART NUMBERS
JUST DIFFERENR VIEWS BECAUSE THATS THE WAY ITS DONE IN AUTOCAD AND I WANT TO MIMICK THAT
BUT NOT CHANGE THE BOM.
JDMather
In the real world - this is an assembly.  (I saw several other issues as well.)
You should mimic the real world in Inventor - then you could use Position Representations.
rclement
THOUGHT SO BUT I FIGURED I TRY TO SEE IF CAN BE DONE IN IPT. GOT ORIGINALLY FROM MCMASTER. NEVER TRIED POSITIONAL LEARN ANOTHER THINGS
TY
Yashasvi23481
Hi @rclement ,
Just a note. When you create assembly, constraint using axis and angle between faces .   That way when you do positional rep, angle can be modified (using modify override by right click on angle constraint). You can also animate the motion from open to close position.
Yash
