After exporting idw to AutoCAD DWG sizes with positive deviation alone performed also negative as (-0) though I didn't write anything in the negative box.
Also the size value does not match.
Hi Alex,
The behavior does not look right to me. It should always be what-you-see-is-what-you-get (wysiwyg). There should be zero fidelity loss on export. Please share the files here so we can take a closer look.
In the meantime, try this workflow to see if it helps. Save the idw file as Inventor dwg (not AutoCAD dwg). Open the dwg file in AutoCAD -> EXPORTLAYOUT. Does it work better?
Many thanks!
