Detail view of section view - Suppressing Issues
luisvaldes23
luisvaldes23
I have made a detail view of section view in order to get the desired representation. Its a worked around by placing the section view off the sheet (doesn't show on a pdf). Is it possible to suppress the section view without suppressing the "definition in base view" arrows on the parent view? Or create my arrows to denote view direction of the section. Autodesk forums.PNG
mozoub
If you do not want to put the view off the screen.
I would suggest blowing up your section view to a larger scale, and then adding a break in the section.
mz
I tried two alternate methods based on what I'd done prior in jobs. The first is just a simple crop on the the section view targeting the area of interest (Section A-A) and the second (Section B-B) is a internal section. B-B could also be cropped if needed. I have both parent views off the sheet as you can see. Suppressing the parents shouldn't be necessary as they remain outside the printable area.
-Mike
luisvaldes23
That's correct is doesn't have to be suppressed. It is a work around and I don't like having stuff out there in the wilder lands of the page.
