Detail view hatch scale
b_owen
b_owen
Hi
When creating a detail view from a section view, the hatching is the wrong scale.
See example below.
parent view = 1:30.
detail view keeps the same scale hatch as parent view even though the view scale is 1:10.
It should be 3 times smaller?
I have done a section view at 1:10 to show what the detail view hatch scale should look like.
Both 1:10 views come from the same parent view, but have different hatch scales.
The work around i currently use is to select each individual hatched body and edit the scale but this takes forever.
Does anyone know a quicker solution?
MikeKovacik4928
It would be nice if there was a way to do this.
I have been doing, what you are doing for a couple of years now,
and yes it does take a lot of extra time.
However it would appear that there is no solution.
If there is, i would be very happy to know about it.
Mike Kovacik
Inventor Pro 2018 & 2022
South Africa
Lucas.dolinarVFXZU
Yes, this is an issue with how the hatch scale is calculated.
The Solution is to use the hatch style without a scale option: SOLID (hehe gotcha)
All jokes aside, this would make a great request for the Inventor Ideas forum.
johnsonshiue
Hi! This has been discussed before. It does look like an as-design behavior.
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Detai...
Many thanks!
Software Test Engineer
b_owen
Thanks for the replies.
In my opinion, its a design fault. But its been like it for years?
Seems a pretty basic thing to me but guess we will all have to live with it for now.
