Hey Phil,
I posted the same issue earlier, see link:
https://forums.autodesk.com/t5/inventor-forum/detail-view-dropping-line-on-update-bug/td-p/7373980
Let's see if @johnsonshiue has a moment to look at this.
If anyone else is familiar with this issue we'd still like to learn more about it.
Thanks!
Hi Phillip and Curtis,
I have replied to Curtis' thread. I am copying the same reply here. The behavior does not look right. Either the body geometry is bad or the body is surrounded by other bad bodies or there is an interference. Could you open the assembly and run Interference Analysis on the components of interest?
Many thanks!
I ran the interference analysis. The parts still won't show up in the drawing detail.
@phillip.shields @Curtis_Waguespack
Pack and go.. email to Johnson...
I started to send the files to johnsonshiue last week, but I we were able to confirm that his hunch that the body geometry was bad, by doing a save copy as of the file in question (the muffler part) and then doing a component > replace on that part with the new copy.
When we replaced the part with a copy of itself in the assembly, the drawing detail view began to work as expected. So I marked the other thread as solved with this explanation as it seems to prove out that the issue was specific to that one part file.
@phillip.shields I think Cris was going to update the file with the copy in the library/CC to fix the errant body geometry and resolve this issue for future work, but you might touch base with him on that.
I hope this helps.
Curtis
I did the save as and then replace but when I open the drawing it still has the detail view issue. Maybe you could make a video showing me what you did? Also, what makes a geometry "bad"?
Hi Phillip,
You mentioned that you ran Interference Analysis. Were there components interfering with each other? If yes, have you made necessary edit so they no longer interfere?
Many thanks!
Yes, particularly the muffler which is the part in question. I actually put gaps on either side of the flange to ensure there were no interferences...still no luck. I have the pack and go of the assembly if you still need it but it sounds like you and @Curtis_Waguespack went through this exercise. I tried to repeat the process he had mentioned with no success.
Hi Phillip,
If possible, please share the files with me (johnson.shiue@autodesk.com). I would like to understand the behavior better.
Many thanks!
@Cris_Davis came by and showed me his trick for fixing it. He rolled the end of part feature to the top(no features in part file) then he rolled the EOP to the bottom again sort of a bootleg rebuild and it worked. Since the part has been rebuilt I can't reproduce the error again. When this happens again I'll pack it up and send it to you. Strange solution to a strange problem.
Ahh good point. In doing the "save copy as", and replace, I think the part was getting rebuilt as it saved, and migrated (that file was created and last saved with 2015 SP1 (Build 190203100, 203)).
When I attempted to do it again today, I couldn't get it to force the "rebuild" during the save. Not sure why?, but I wasn't testing 1 to 1 today, since I was in the middle of something else and using a different project with different library paths, etc.
In any case, it pointed to an issue with that specific part file, and that the body geometry was bad as johnsonshiue suggested. If I had to guess it would be related to the feature Thread1 being suppressed, but that's only a guess.
I hope this helps.
Curtis
