I used the Spur Gear Design macro in an assembly, and was not pleased with the results. I did not double check the software before we had them made, so I had to spend a couple of hours on a mill putting a 45 on the end of each tooth to make them work.
How can I prevent this going forward? Obviously double checking the results of the software's calculations would have caught the error, but what information did I enter incorrectly? I am attaching the gears to this post so you can see the teeth do not mesh properly.
