Design Assistant not showing up
Coworker just got a new desktop with windows 10. He does not have the design assistant option when right clicking on a file. Is there a setting that turns this on?
Mark.Lancaster
@Anonymous
It sounds like Inventor is not properly registered with the OS
Use the following steps to re-register Autodesk Inventor with your operating system:
1.  Exit Inventor if still running
2a.  Win 8/8.1/10: Select the Windows start button and type CMD (but do not hit an enter)
2b.  Win 7:  Select the Windows start button and type CMD in the search field (but do not hit an enter)
3.  When CMD or command prompt appears in the list, right mouse click and select run as admin
4.  When the command prompt appears, navigate using dos commands to C:\Program Files\Autodesk\Inventor <version>\Bin or where your Inventor.exe is located if you changed the default install location of Inventor.
In this example I'm navigated to my Inventor 2018 (exe) location.
6.  Type Inventor.exe /install.
Wait a few mins and restart Inventor.   At this time you will not see anything occurring.  Don't panic.  Smiley Very Happy  However if you launch Windows task manager you can watch the Inventor.exe process (and see when it ends).
Does that resolve the issue?
Mark Lancaster
mcgyvr
Do they have pack and go, Iproperties, purge,etc... in their right mouse menu in windows explorer?
If not then it may be that their user permissions aren't correct and registry settings could not be set or something to create that..
No idea if the Inventor reset utility might fix that or if they need to get correct rights and then do a reinstall..
He has no options. I got it to open design assistant to open with the open with option.
DannyHubbard
Might be related to their User Account Control settings, see the following.
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
jasonhoffmanGQWA8
I was having issues using pack and go, This fixed the issue in inventor 2022.
Many Thanks
Jason
