Design Assistant for 2020 error 80004005
ciaran.gibson
ciaran.gibson
When copying and renaming an assembly with 282 files I get the error 80004005. I have tried making sure the part is up to date with a migrate save and still get this error. Closest I can find describes it as a runtime error, is this assembly just too large to copy it all in one go or is there a workaround?
CCarreiras
Hi!
If you want to do model copies, try "iLogic Design copy".
This efficient tool will copy and rename your files maintaining all the links associated to the model.
Design assistant is a very faulty tool compared to this one.
The renaming options are a little restricted, only prefix suffix or replace.
The Part Numbers will update.
Despite the tool's name, you don't need to have iLogic rules in the models to run the tool, I don't even know why this tool is called like that. "Design copy" should be enough.
CCarreiras
CCarreiras
Also, in Autodesk app store, you will find some tools to copy and rename parts a lot more effective than DAssist.
An example:
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=474004987007055323&appLang=en&os=Win64
CCarreiras
ciaran.gibson
Thanks so much, I will try use the ilogic design copy and see if it can do what I need.
