Design assistant - doesn't appear on ribbon Inventor 2018
barry_dawes
barry_dawes
Design assistant doesn't appear on the ribbon.
The add-on box is checked, and all other add-on's appear.
Inventor Pro 2018.
Thanks, Barry.Dawes
johnsonshiue
Hi! Could you take a snapshot of Ribbon bar you are seeing? You can also try resetting Ribbon. Right-click on Ribbon -> Reset Ribbon Panel. If it still does not work, go to All Programs -> Autodesk -> Autodesk Inventor Pro 2018 -> Tools -> Inventor Reset Utility -> reset it to 2018.
Many thanks!
Software Test Engineer
SBix26
Do you mean Design Accelerator or Design Assistant?  Design Assistant runs outside of Inventor, and does not appear as an Add-in as far as I know.  Design Accelerator appears as an add-in, but the Design tab on the ribbon only appears when an assembly file is active.
As suggested above, an image of what you're seeing would be helpful.
Sam B
Inventor Pro 2019.0.1 | Windows 7 SP1
LinkedIn
