Design accelerator's filename in assembly
lis_wang
lis_wang
I used design accelerator to create two different shaft. These two different shaft shows the same part number in the part list and 2 qty. This is no reasonable.
May I know how to create two shaft with two different name in design accelerator?
lis_wang
Is there anyway to solve the problem?
Steven_Gao
You can use the File Naming function in the Shaft dialog and change the display name of them. Please refer to the attached picture.
Steven
lis_wang
Thanks. You solved my problem.
