design accelerator bolt connection
ambrosiPZ23D
ambrosiPZ23D
is it possible to remove the hole from the list.
CCarreiras
HI!
Yes you can dismiss the holes:
CCarreiras
ambrosiPZ23D
Thanks for your answer
but it is no possible to eliminate the holes, the X are disabled, (see below).
James_Willo
Are you on Inventor 2023.1 or later? This was an enhancement.
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-ADBF2C30-818F-42A8-8BED-EF8D4925287C
James W
Inventor UX Designer
ambrosiPZ23D
Now 2022, in the next few days i will install 2024.
