Description property too long to show in view label
AlejandroAvila01
AlejandroAvila01
In our darfting dpt we make a laser cut drawing with all the pieces to cut in a big assembly, we attach a *description* iproperty to the label in every view so the shop can understand what that piece is for.
Descriptions tend to be quite long some times, making the arrangement a bit complicated as you can only put the description in one line.
I was wondering if there is a way to constrain this property to a certain length and when it reaches that length skip to the next line like in img 2?
johnsonshiue
Hi! The view label the control is fairly limited. But, in a drawing sketch text, you may be able to enable the text box and dimension it to certain size. Then any text exceeding the box will be moved to the following line.
Many thnaks!
Software Test Engineer
