Derived part not creating flat pattern
dwgESGWF
dwgESGWF
Hello, I created a derived mirrored part from a Sheet Metal part I had. I see it inherits the sheet metal style and everything as it should, but it doesn't want to generate a flat pattern. It just shows the part as it is. The thing is that the original part has a couple of holes that the mirrored one doesn't, so that's why I need to have two separate parts.
kacper.suchomski
Hi
The sheet thickness in the rule is different from the model thickness. The value must be identical.
Fix the sheet settings and the flat pattern will work.
Kacper Suchomski
JDMather
@dwgESGWF
When I go into the Sheet Metal Styles it is set to different Thickness than the part.
When I set to correct Thickness - it flattens.
Interestingly though, the original file is also set to incorrect Thickness but it flattens.
Somewhere it looks like it was a conversion from inch to mm issue.
johnsonshiue
Hi! I believe there is a unit confusion issue in the Sheet Metal Style. The sheet metal parts are in mm but the active Sheet Metal Rule does not specify the Thickness unit. As a result, the Thickness seems to be derived as mm but the actual body thickness is 0.075 in.
I have reset the parts' unit to inch so that they are all in sync. Please take a look at the attached file.
Many thanks!
Software Test Engineer
dwgESGWF
Thank you! Yeah, this thing of mixing units gets complicated when things are in mm but manufacturing needs inches. Thank you all for your help. Learning something new every day
