Message 1 of 8
09:16 AM
Our default workflow (without Vault) to substitute a derived parent part is: save the original part as a new number then close the original, rename it temporarily and then open up the new derived part and when it cant find the parent just point it to the new one. The issue with this is if the original parent part is in any other assembly obviously you have to unload it from RAM before you can change its name (i.e. shut everything down)....this is a pain.
Isn't there a way in 2018 to just open the derived component (a mirror of the parent) and just point it to the newly saved part?
I hope I'm clear enough, I feel I'm way too verbose in describing what I want to do. ![]()
