Derive Sketch not visible With Block
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a normal sketch in a part document.
Why is it the following the case:
I have a sketch with a line and a block (square in the sketch).
When I create a new part and use derive the previous part into this part the sketched line is only available when selecting the block also.
If you deselect the block also the line disappears from the derive.
If you remove the block from the part one, the line is again selectable or visible in the derived part function.
Maybe this is a bug.
And it would be great to have both functionalities.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
