Inventor Forum
Derive assembly in Inventor 2013 SP1
3 REPLIES 3
petrxn
804 Views, 3 Replies
We have found that after installing SP1 for Inventor 2013 is nearly impossible edit derived assembly. It takes very long time for open dialog of Derived assembly, without SP1 it takes approx. 2mins. for assembly of 20000 instances, with SP1 it takes more than 2 hours! This we are able to reproduce on each of our station. And more, there is still not corrected bug with save setting of hole patching range. This setting does not remember min and max value and after re open this dialog the range is set back to default value 10-9999mm.
I have tried ti disable antivir  and all unnecessary services - no effect.
Inventor 2013SP1, Win7SP1 64bit, Eset Endpoint Antivirus 5.0.2126
Petr
3 REPLIES 3
Yijiang.Cai
in reply to: petrxn
Hi Petr,
When using the common assmebly to make derive, it looks fine when editing the derived assembly. Maybe it is related to the dataset you have. So could you attach the dataset or send me @ river-yijiang.cai@autodesk.com for further investigation?
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
petrxn
in reply to: Yijiang.Cai
Hi River,
thank you for response. I have sent you email with link to the model and with short description.
Best regards
Petr
Ryan.Martinez
in reply to: petrxn
Uninstal SP1 autodesk just took it down due to memory errors
P.D.S. 2015
P.D.S. 2016
