deleting parent drawing views
jernejL2VC5
jernejL2VC5
hi, when deleting a parent view in drawings, I do not get a prompt if I want to keep any of the dependents, it just automatically deletes. Is there a way, if I place a base view, make a section from the base view to then delete the base view and keep the section view?
swalton
As I understand it, Inventor creates a parent-child relationship between a base view and and projected or section views.
It is possible to move the base view outside of the drawing boarder.  The view will not print on the sheet.
Steve Walton
Inventor 2025
Vault Professional 2025
johnsonshiue
Hi! Or you may suppress the parent view.
Many thanks!
Software Test Engineer
Paul-Mason
It quite possible that the prompt has been turned off from within APPLICATION OPTIONS - PROMPT tab, as to exactly which one it is I don't know.
Inventor 2027 Pro
HP Z4 G4 workstation
Xeon Processor Intel(R) Core(TM) i9-9920X CPU @ 3.50GHz (3.50 GHz)
Memory 128 GB (128 GB usable)
Graphics Card NVIDIA Quadro P4000 (8 GB)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
lauri_barnhart
Greetings, @jernejL2VC5,
Hope you are well. Just checking in to see if any of the replies by swalton, johnsonshiue or Paul-Mason provided the information you needed to resolve your issue? If any of the replies helped, please consider clicking on the 'Accept Solution' button on the post(s) that helped. If you are still needing assistance, please provide an update here so we can continue to help.
Best,
Lauri | Community Manager
jernejL2VC5
thank you, will mark this as accept solution tho certain workflow details in inventor don't completely make sense to me. Thank you
