Hi! When I try to delete Title Block I get following message (see attached picture) - "To delete a drawing resource, first delete all references it from drawing sheets and other drawing resources."
Seems that I've already delete references to it from the drawing sheet, but I can`t understand what is the drawing resources and where they lays on the computer? What should I actually do to delete this Title Block?
Thank you!
Best,
Roman
Solved by admaiora. Go to Solution.
@Anonymous
Not sure why you're posting twice about the same thing https://forums.autodesk.com/t5/inventor-forum/delete-title-block/m-p/8513996/highlight/false#M727883
Mark Lancaster
& Autodesk Services MarketPlace Provider
Are you looking to delete this just in this drawing or in your template as well in which this came from?
Does your title block have a company logo that you you inserted an image to? When you possibly inserted that logo you linked it to the logo location? Instead of breaking the link?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Open your Sheet Format. Delete the one that is using the title block you want to delete.
Hi! I vaguely remember seeing this issue in 2014 or earlier. It seems like a corruption to me. Could you share an example file here?
Many thanks!
Here is the example of file (attached .idw file, Inventor 2019 version). Now the title block I need to delete contains nothing, but I still can't delete it. Thank you for help!
Best,
Roman
Hi Roman,
try this
Admaiora
Nowadays good answer is not enough.
Need good presentation
Need to fire my PR manager.
I personally don't understand why one would want to delete all of the borders in a format. Like you stated, just find the problem child and figure out how to break the connection. Then maybe delete it if need be.
Inventor Pro 2018
I am having same problem with deleting a titleblock type. Where do I find the drawing resources folder in REVIT to delete the stuff you show?
Hi
Delete Sheet Formats first (right klick →delete), and then it will be possible to delete the title block.
REVIT? You've posted to a topic in the Inventor Forum, which won't be much help with Revit...
Sam B
Inventor Pro 2021.2.2 | Windows 10 Home 2004
LinkedIn
