Delete Title Block
Delete Title Block
Hi! When I try to delete Title Block I get following message (see attached picture) - "To delete a drawing resource, first delete all references it from drawing sheets and other drawing resources."
Seems that I've already delete references to it from the drawing sheet, but I can`t understand what is the drawing resources and where they lays on the computer? What should I actually do to delete this Title Block?
Best,
Roman
Replies (13)
Mark.Lancaster
@Anonymous
Not sure why you're posting twice about the same thing https://forums.autodesk.com/t5/inventor-forum/delete-title-block/m-p/8513996/highlight/false#M727883
Mark Lancaster
Cadmanto
Are you looking to delete this just in this drawing or in your template as well in which this came from?
Does your title block have a company logo that you you inserted an image to?  When you possibly inserted that logo you linked it to the logo location? Instead of breaking the link?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Frederick_Law
Open your Sheet Format.  Delete the one that is using the title block you want to delete.
johnsonshiue
Hi! I vaguely remember seeing this issue in 2014 or earlier. It seems like a corruption to me. Could you share an example file here?
Many thanks!
Software Test Engineer
Here is the example of file (attached .idw file, Inventor 2019 version). Now the title block I need to delete contains nothing, but I still can't delete it. Thank you for help!
Best,
Roman
admaiora
Hi Roman,
try this
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Thank you!  It works 🙂
SBix26
Exactly as @Frederick_Law described in message 4...
Sam B
Inventor Pro 2019.3 | Windows 7 SP1
LinkedIn
Frederick_Law
Nowadays good answer is not enough.
Need good presentation Smiley Wink
Need to fire my PR manager.
Cadmanto
I personally don't understand why one would want to delete all of the borders in a format.  Like you stated, just find the problem child and figure out how to break the connection.  Then maybe delete it if need be.
Inventor Pro 2018
Best Regards,
Scott McFadden
shannon.glassley
Observer
Observer
I am having same problem with deleting a titleblock type.  Where do I find the drawing resources folder in REVIT to delete the stuff you show?
Hi
Delete Sheet Formats first (right klick →delete), and then it will be possible to delete the title block.
SBix26
REVIT?  You've posted to a topic in the Inventor Forum, which won't be much help with Revit...
Sam B
Inventor Pro 2021.2.2 | Windows 10 Home 2004
LinkedIn
