@Anonymous wrote:
Hi Carlos, thank you for your prompt answer.
I work in a company with other twenty designers. We all use the same Vault Project, and in our root folder we have all our projects, divided in different folders by type of products, so we have a very ramified folders tree.
For this reason we usually have to save our file in subdirectories with long path, and when we create a new .ipn file it could be usefull if Inventor takes the path of the .iam file as default folder. Instead, every time we create a new file, Inventor takes the root directory as default folder the first time, and the last used folder the next times. It is not usefull, because we have to change folder every time. It could be more userfull if Inventor will suggest the same folder of the referenced file.
Thank you.
Marco
Well.. It doesn't work like that currently.. You have found out how it works and that behavior can't be changed AFAIK..
You can suggest your idea on the Inventor idea station for possible implementation in future versions.. (but don't start holding your breath now 🙂 )
http://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
