Default appearance
Default appearance
Default appearance
For some reason the default appearance has an image attached to it. I tried opening the template .ipt file from the template directory, removing the image and saving the file. But when I create a new .ipt part using the template the image  is attached to the default appearance again. I've attached a screenshot in case my wording isn't very clear. Can anyone help? Thank you.
salariua
after you edited the template did you saved the style to library?
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Thank you Adrian. Saving the style to the library after editing the template worked.
