Cylinder surface rectangular section to circular section transition
mech_maran
Observer Observer
mech_maran
Observer
Observer
Hi All,
I am having an issue with making transition piece. and I have attempted to resolve the issue myself, but have not been successful. if anyone suggest how the transition piece should be done?
To help you diagnose the problem, I have attached the part model.
Please let me know if there is any additional information required to resolve the issue.
Thank you for your help in advance.
kacper.suchomski
Hi
Can you sketch your expected result?
Which exact edges are to be included? Internally or externally?
Please specify by sketch what exact shape you want to model.
Kacper Suchomski
Alexander_Chernikov
What version are you working on?
It is not entirely clear why such a part is made on the basis of sheet metal.
Try to create the loft surface first, and then set the thickness.
Example made and saved in version 2021
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
johnsonshiue
Hi! I think Lofted Flange2 in your original file seems to be desirable. You just need to make a circular cut at the bottom. Is that what you were looking for?
Many thanks!
Software Test Engineer
mech_maran
Observer
Observer
Thanks a lot for your support!
Thiru
mech_maran
Observer
Observer
I got the solution using sheet metal loft method, however thanks for your support!
Thiru
