Cutting
Cutting
julietang
Cutting
julietang
Attached is what I drew/ when i'm on my sketch 2 and click the cutting tool, only 3  are highlighted green and there's one that isn't green and i can't click on it. does anyone know what is wrong there?
thank you.
CGBenner
@julietang
Hello.  Your attachment did not... attach. 🙂
Chris Benner
julietang
ATTACHED
julietang
oops - i have attached
SBix26
The sheet metal Cut tool still uses the old profile recognition routine that requires point-to-point connectivity (try the Extrude tool and you'll see that it does recognize that loop as a valid profile).
I found that in the spot circled below the end points of the two lines making up the edge do not coincide, so there is no continuity there.  Just use a Coincident constraint to make them coincide and the Cut tool will be happy.
Update: the same is true on the other side of that loop, so there are two spots to fix.
Note, though, that this sketch is massively under-constrained-- lower right corner says 224 dimensions (and/or constraints) are needed.
Sam B
Inventor Pro 2024.1 | Windows 10 Home 22H2
johnsonshiue
Hi! As an alternative workflow before the Cut adopts the new geometry-based profile recognition ability, you may use Extrude Cut to achieve the same goal.
Many thanks!
Software Test Engineer
