Inventor Forum
Cutting foamglass insulation
4 REPLIES 4
369 Views, 4 Replies
I need to learn software to cut foamglass on a windtech cutter as i have no exposure to the machine or its licenced software are there any software packages similar that i could learn from so when i do get exposure i could be some what proficent many thanks jim
4 REPLIES 4
mcgyvr
@Anonymous
Have you used any CAD software?
Are you a student or teacher?
Most Autodesk software is not free to unless you are a student..
You can get access to Fusion as a "hobbyist" though..
Or you can run 30 day demos of most of the software but 30 days may not be sufficient to become proficient..
I have no idea what the windtech software is but its likely very easy assuming you have used some sort of cad software before..
Why that specific machine/Software? job opening near you?
in reply to: mcgyvr
Thanks for your reply and no have no cad experiance complete beginner wind
tech programme is 2d x and y axis on a 3.51 microsoft computer just need
to make a start cheers
mcgyvr
In that case I'd suggest the free version of Draftsight..
https://www.3ds.com/products-services/draftsight-cad-software/free-download/
Its virtually identical to Autocad but its free
Thats the best 2d choice
in reply to: mcgyvr
Thank you for your advice much needed sounds perfect cheers
