Inventor Forum
Cutout Part within Circular Constraint
15 REPLIES 15
Message 1 of 16
1263 Views, 15 Replies
Hi there. I'm trying to make a turbine fit within a certain circular radius, but I'm having a hard time getting AI to let me extrude a circle to cut the outer edges of the turbine blade.
Any help would be greatly appreciated.
Thanks!
15 REPLIES 15
Message 2 of 16
SBix26
All you need is an outer circle larger than the existing blades, then select the territory between the circles as the profile for the Extrude/Cut operation.
But I'd suggest doing this operation in the part file, not in the assembly.
Sam B
Inventor Pro 2019.0.0 | Windows 7 SP1
LinkedIn
Message 3 of 16
in reply to: SBix26
Hi @SBix26. Thanks for the response. You were totally right about just using two circles. However, as I'm doing this I'm still encountering a problem with the extrusion:
Create Extruded Feature: problems encountered while executing this command.
It's almost acting like the turbine isn't a solid. Any thoughts?
Also note that I cannot do this in the .ipt file because the turbine blade comes out as a mesh not a solid.
Thanks!
Message 4 of 16
Hi there. I'm trying to cut the edges of a turbine so that it fits within a 15cm diameter circle. However, when I go to extrude between the two circles, I'm encountering an error:
Thanks!
Message 5 of 16
Xun.Zhang
Look at the image, it sounds like the cut extrusion is not touch any component yet, would you mind increase the distance value to a bigger one such as 100mm for another try?
Thanks!
Xun
Message 6 of 16
in reply to: Xun.Zhang
Thanks for the response. However, I'm having the same problem.
Message 7 of 16
Xun.Zhang
Hi Sdale,
From the image, it seems none of components was automatically selected for cut extrusion which is incorrect, would you mind send me a sample data to take a closer investigation via xun.zhang@autodesk.com.
Thanks!
Xun
Message 8 of 16
Xun.Zhang
Hi Dale,
Thanks for sharing the data. I am sorry that all of propeller component are mesh data which has no volume here for cut extrusion. Mesh data is lack of operation compared with solid geometries.
So, the first step more like to create a solid before cut extrusion.
Hope it helps!
Xun
Message 9 of 16
How should I go about doing that? I've tried using the Autodesk Mesh Enabler Environmental Add-In, but it only creates a surface, not a solid.
Thanks!
Message 10 of 16
johnsonshiue
Hi! It looks like the blades are imported bodies and Inventor has trouble performing the Boolean operations. Please share the files here so forum experts can comment further.
Many thanks!
Software Test Engineer
Message 11 of 16
in reply to: johnsonshiue
Thanks!
Message 12 of 16
And here's the original .stl file.
Message 13 of 16
Any luck with those files?
Thanks!
Message 14 of 16
Xun.Zhang
Download meshmixer and try to convert to solid as below.
Hope it helps!
Xun
Message 15 of 16
Xun.Zhang
Message 16 of 16
Thank you for the response Xun. I'm still having problems with doing a cut extrusion through the blade even once it's converted to a solid in MeshMixer. I've attached it here if that helps.
Thanks for the help!
