Cut with surface
Cut with surface
Hello, I want to cut the blue surface with the red one. Can anybody tell me how to do that, maybe make a video or something. Thanks.
Replies (8)
SharkDesign
Is that a part file?
Why are you using a surface? Can you not just use an extrude cut?
  Expert Elite
  Inventor Certified Professional
SharkDesign
Try split to split the body using the surface, and then delete face, but use the body command.
  Expert Elite
j.palmeL29YX
Post your file please.
Jürgen Palme
johnsonshiue
Hi! Is the red face a surface or a solid body? You can use Thicken/Offset command to create a zero distance surface. Then it can be used as a tool to cut.
Many thanks!
Software Test Engineer
It is a body @johnsonshiue . Here are the files @j.palmeL29YX .
SharkDesign
Those files are a completely different thing.
Your question is about surfaces but you attached two solids. Are you wanting an answer for surfaces or solids?
  Expert Elite
SharkDesign
Here's both methods, you can't see from the video, but the first thing I do is double click the cylinder to do an edit in place.
https://knowledge.autodesk.com/community/screencast/0dda9302-0892-482b-9297-302cffac8185
  Expert Elite
My question was about solid, but it's worked thanks you.
