I have created a Sheet Metal curved part.
I then created a plane in front of the curved solid with a sketch that I require to shape the curved solid further.
I try to use the cut extrude for a cut normal function on the sheet metal tab, but to no avail. Sometimes this works and other times it does not.
I need this part to eventually flat pattern so as to supply an accurate file for laser cutting.
Is there any other way of doing this. This method is wasting my time and I am getting nowhere. 😞
Please let me know if you require any additional files, information and explanation and I will oblige.
