Cut Command Not Working Properly in Sheet Metal Environment
a.brusamolino
a.brusamolino
Hi everyone!
Just a curiosity: I have this bent metal sheet, and I’d like to make a perpendicular cut on it. The sketch is as follows, and the cut I want to perform is only on the inner surface.
The issue is that the "CUT" command in the sheet metal environment doesn’t recognize the contours I want, while the "EXTRUSION" command in the "3D MODEL" environment does.
Basically, with the "CUT" command I can’t remove the small regions on the sides (red arrows).
Do you know why this happens? Is it something that can be fixed?
I’m attaching the file for reference.
Thanks to anyone who can help me!
kacper.suchomski
Hi
It works for me.
I checked on version 2026 and 2025.2.1
This was probably a bug that was fixed in subsequent releases.
ScreenRecorderProject684.mp4
Video Player is loading.
Current Time 0:00
Duration 1:35
Loaded: 10.50%
Stream Type LIVE
Remaining Time 1:35
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    Kacper Suchomski
    YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
    a.brusamolino
    Hi @kacper.suchomski
    ok, then it’s probably a bug that they fixed in later versions. I’m using version 2023.5.1.
    Thanks a lot for the detailed video!
    SBix26
    I think the answer is that in Inventor 2023 the Cut tool was still using the old profile recognition routine that required points at each change of profile element.  The Extrude, Revolve, and some other tools were using the new profile routine that efficiently finds those areas without requiring points.
    In your case you could repair your sketch by simply adding sketch points at the intersections where there are no end points and the Cut should work as desired.
    In 2024 (if I remember correctly, but I'm too lazy to look it up), the Cut tool was converted to the newer profile routine, and it now works exactly like the Extrude tool.
    Hope that helps, and that my memory isn't too hazy.  I definitely don't miss the days of trying to figure out why a somewhat complex sketch wouldn't work and trying to redefine sketch constraints to make an extrude or cut happen.
    Sam B
    Inventor Pro 2026 | Windows 11 Home 24H2
    a.brusamolino
    Thanks @SBix26 for the explanation!
    In the end, I solved it by manually rebuilding the other three inner arcs as well. Initially, they were created using the mirror command starting from the first one in the top left, but apparently, something about it wasn’t working properly. If this happens again with other sketches, I’ll keep your advice in mind and add sketch points at the intersections.
    Yeah, I totally get you! Sometimes it’s frustrating not knowing why certain sketches aren’t recognized. Luckily, they’ve fixed it in the newer versions.
    Thanks again.
    Type a product name
    ______
    icon-svg-close-thick
    Cookie preferences
    THIRD PARTY SERVICES
    icon-svg-hide-thick
    icon-svg-show-thick
    Qualtrics
    Akamai mPulse
    Digital River
    Dynatrace
    Khoros
    Launch Darkly
    New Relic
    Salesforce Live Agent
    Wistia
    Tealium
    Upsellit
    CJ Affiliates
    Commission Factory
    Typepad Stats
    Geo Targetly
    SpeedCurve
    Qualified
    icon-svg-hide-thick
    icon-svg-show-thick
    Google Optimize
    ClickTale
    OneSignal
    Optimizely
    Amplitude
    Snowplow
    UserVoice
    Clearbit
    YouTube
    icon-svg-hide-thick
    icon-svg-show-thick
    Adobe Analytics
    AdWords
    Marketo
    Doubleclick
    HubSpot
    Twitter
    Facebook
    LinkedIn
    Yahoo! Japan
    Naver
    Quantcast
    Call Tracking
    Wunderkind
    ADC Media
    AgrantSEM
    Bidtellect
    Bing
    G2Crowd
    NMPI Display
    VK
    Adobe Target
    Trendkite
    Hotjar
    6 Sense
    Terminus
    StackAdapt
    The Trade Desk
    RollWorks
    Your experience. Your choice.
