Trying to create a custom view that looks something like this:
I want it to be at an exact angle relative to another view as my objective is to make a model which I'm using for labelling certain geometric dimensions (length, shell thickness).
I'm planning on doing this for many shells that look like this, and so I'm wondering if there's a way to specify a view that is at an angle to, say, the bottom of the view cube so it's standard across all my pictures.
Any thoughts?
Solved by Tom_Sturtevant. Go to Solution.
Hello -
One way to achieve a specific view angle is to define a work plane and use View > Look At to rotate the view.
For your example try using the "Angle to Plane Around Edge" work plane construction, select the origin X-axis and the origin XZ-plane and specify -15deg rotation.
You can add a Design View (View > New in the browser) with that view set and save it as a custom template (File > Save As > Save Copy As Template).
Hope that helps!
T.0.M.
Hi Tom,
The rotated plane idea is perfect! Should have thought of doing it just purely geometrically haha.
Thanks for this simple solution 🙂
