Inventor Forum
Custom Section reporting overall length instead of unit QTY
10 REPLIES 10
Message 1 of 11
henryjoseph9804
539 Views, 10 Replies
Hi everyone,
Need some help please, so I know that traditionally if you use a CC section it will give the total length of all the same length items in the assembly under the 'QTY" Column. Whereas if you use a nut or bolt etc. it will give you the qty of the items in the qty column.
I have used a CC section in my assembly but used it as a custom piece and not a standard, how do I get it to show the total units of the section used in the assembly and not the total length of all the units added together.
10 REPLIES 10
Message 2 of 11
In the Part file, do this and select Each:
Message 3 of 11
LOL @EdvinTailwind , thank you so much you're a champion!
You've been consistently assisting me with my problems, it is truly appreciated.
Message 4 of 11
Unfortunately it isn't updating my BOM or showing the QTY in a new BOM, any idea why?
Message 5 of 11
In the BOM (not Parts List), make sure the file is marked correctly:
And in the Parts List, make sure the Quantity field isn't manually set, eg Static Value (blue text in blue frame).
Message 6 of 11
Please see below item 1 -
Message 7 of 11
Also in Parts list there is no 'Static Value'
Message 8 of 11
That's odd...
I'd actually advise you to restart Inventor, it usually helps when it behaves strange. If it doesn't help, could you upload the faulty part here?
Message 9 of 11
I agree, when you mentioned where to change the G_L to 'Each' it made so much sense, so I thought it would work.
I have restarted IV and unfortunately no change.
Please see attached for the part in question.
Message 10 of 11
The quantity turns out fine when I test this part in an assembly (using Inventor 2023.2).
How about trying Manage -> Rebuild All in the assembly?
Message 11 of 11
Hah! You absolute beauty, rebuild all immediately fixed it. Thanks so much for the assist!
