One workflow item I seem to be doing quite often for 3D printing (or at least want to do is):
- Find some model I like on thingiverse or similar (or I may make my own in Blender or similar)
- Export it as an STL
- Import it to Inventor
- Set the size of the STL so I can modify features or at least get it to the size I expect
- Export it again so I can print it
I'm specifically having issues with resizing an STL. I know an STL is a unitless file, and I know you can set the units on import, but I'm not seeing any way to set a custom scale (for example, working with units in Blender has been very clunky to me, so resizing in Inventor would be far preferable).
Ideally what I want to do is add a dimension constraint between two points and have it scale the rest of the model accordingly, but even just manually entering a decimal scale would be acceptable.
Is this possible, and if so, how?
