Hi guys, I am trying to get the description in my ipart to say cut to "length"
I can't seem to get it to work, and no idea why. The parameter and description have the same name etc, but it just wont display the driven section properly.
Also any input on how I have gone about setting up the part to do pricing and naming etc will help.
Cheers, Sam.
Solved by blair. Go to Solution.
You're almost there, just missing a couple of "Check" boxes selected, in the Top box, then make sure you have your proper fields in your iProperties box. You should then get the results as show in the bottom box. Any changes to the parameters in the part will be updated and show up in the iProperties as well as any drawing parts lists.
