Custom iproperties set for a part within a sub assembly of my main assembly. Can I get BOM to see those?
crothgebCF5AM
crothgebCF5AM
I have an assembly that has iparts and iparts within a sub-assembly. When I go to make a BOM list with custom properties that are set within the ipart it is not recognizing the properties for the ipart within the sub-assembly.
I hope I'm explaining this well enough to understand.
A.Acheson
Hi @crothgebCF5AM
  1. Are you referring to BOM in Assembly or Partslist in Drawing?
  2. Can you share an image of missing iproperties? Show image in the ipart where the custom iproperty are created and where you want to see the iproperties in the assembly BOM/Partslist.
Regards
Alan
johnsonshiue
Hi! This behavior could be due to incorrect iPart table or out-of-date members. Please share an example (Inventor files). I would like to understand the behavior better.
Many thanks!
Software Test Engineer
crothgebCF5AM
USING THE VIEW REPS AND HIDING EVERYTHING EXCEPT FOR THE SPECIFIC PART I NEEDED WORKED. SORRY AND THANK YOU FOR THE REPLIES!
