Custom 'General' table in template
faye_quinn4DEVD
faye_quinn4DEVD
Hi, is it possible to use the Style Editor or any other function to set the column titles for all general tables? So I'll set this in my company template so each time we add a General Table it brings through the below titles:
Just to save time with changing the names each time when I start t create a drawing?
Thanks!
YannickEnrico
Yes, simply right click your table -> Edit table style -> Default Column Settings
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
faye_quinn4DEVD
Thank you, that all worked on the style editor, but now I'm seeing the prompt for "The following style definitions in template differ from ... the style library"
I've gone into my project to follow the instructions to change this but I cant edit the project, so the changes I've made arent following through
YannickEnrico
Okay, so first go to the project, and make sure Use style library is set to read/write
Then, after making your changes to the style library you go to Manage -> Styles and Standards -> Save
And then you can save your drawing by pressing save -> Save Copy As -> Template
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
faye_quinn4DEVD
Perfect all done! Thank you
