Custom Colour Schemes - Inventor Application Options
Vagulus
Message 1 of 11
Vagulus
I can't find a colour scheme that suites my aging eyes.  Currently (using the 'Presentation' theme) a model displays like this
which is a pain in the eyes.  It would be nice if the theme produced something like this
but the themes offered in AI2018 don't include this.
I have played with the 'Inventor Color Scheme Editor'' in the past but that's a bit risky, I believe.
Can I download other themes from somewhere?
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
Replies (10)
Message 2 of 11
Please check this article http://www.cadforum.cz/cadforum_en/changing-colors-of-the-inventor-color-schemes-ui-tip10596
i think there is an answer for your question. Thank me later.
Message 3 of 11
PaulMunford
Check your background settings. Changing background from 'Single color' to 'gradient' will get you closer to your prefered image.
Customer Adoption Specialist: Autodesk Informed Design
Help | Learn | Forum | Blog | Ideas | Sample content | Linkedin
Message 4 of 11
Vagulus
I have 'gradient' set, but it is the colour of the model image I am concerned about.  I do get a change by setting the material away from generic but it is still not a clear image.
Albert Einstein
Message 5 of 11
blair
Change the color of the "Generic" to a color that suits your eyes and then save this file "Save as Template" and save the to "Standard". Every time you start a new part it will use the "Standard" with the altered color for "Generic".
Delta Tau Chi ΔΤΧ
Message 6 of 11
Vagulus
Hi blair
I don't quite understand what you are saying.
I created an 'anything' IPT and it looks like this
Now what?  Do I use Inventor Color Scheme Editor to change the color?  Is that what you are saying?
I changed 'Work Feature' with the Editor
But it has no effect on Inventor (yet).  Perhaps it needs a reboot.
Then, what is it you want me to do with the file?
Albert Einstein
Message 7 of 11
blair
If you don't like the default color that Inventor uses for it's standard part generic material. Then create a new part, change the appearance of Generic material to a color that suits you and then save this new IPT file as Standard.ipt using the Save as Template option. The link below will show you how it's done.
http://autode.sk/2tSqerf
Delta Tau Chi ΔΤΧ
Message 8 of 11
johnsonshiue
Hi! I think I know what you are talking about. It looks a bit blurry. Besides changing appearance, you could also try changing the Lighting Style. Go to View -> change the default Lighting from Grey Room to Two Lights or Standard. Do you like it better? The main reason why Grey Room was chosen is because it offers better interpretation of legacy appearance styles.
Many thanks!
Software Test Engineer
Message 9 of 11
Vagulus
Thanks blair
That is an interesting screencast - although it doesn't work for me.  I have eMailed the author and I'll keep you posted on what we come up with.
Albert Einstein
Message 10 of 11
Vagulus
Albert Einstein
Message 11 of 11
Vagulus
I think I have finally found what I was looking for.
Firstly,  I found that I get a HUGE increase in available options if I use the drop-down menus at the top of the toolbar
and select 'Autodesk Materials Library' and 'Autodesk Appearance Library' respectively.
I did that and by selecting the appearance 'LED - Yellow On' I get the effect shown below
Which is about what I would like.  I saved the IPT in which I made the change to a new name in the folder where I find my usual standard template (in my case Metric) and 'Bob is your proverbial Father's Brother' as they say here in the Antipodes.
The key was changing the libraries.
Albert Einstein
