Curved Plate Flat Pattern
karthur1
karthur1
I am trying to model a piece of plate that will be bent the "hard way".  Modeling it is not to bad, but I also need to get the flat pattern.  The problem that I am having is entering the k-factor so that it will give me the correct value for the flat length.
There are "Beam Theory" formulas that will give me the radius of the neutral axis.  Since I know that and the bend angle, I can calculate what the proper length should be for the flat.  With this part, the NA is at a 26.88in radius.  At a 90° bend, the flat pattern will be 42.223in long.  I can keep playing with the k-factor until I get it to give me the correct length, but then if the inner or outer radius change, the k-factor doesnt work.
I would rather have a formula that would calculate the k-factor.
Does anyone know how to do this with Inventor so that it will give me the value for the length?
Thanks.
IgorMir
Hi Kirk,
Would that part work for you? Please see the attached IV2018 file. That way you can get an unfolded length of the part.
Cheers,
Igor.
Web: www.meqc.com.au
karthur1
Igor,
Thanks for the file, but that does not give the correct flat length.  The model that I posted is a simplified version of what I am really trying to get to work.  We are actually trying to roll a "Tee" beam.  I would like to get Inventor to give me the flat pattern and the correct flat length.  I can get a flat pattern, but the flat length is not correct.
For the attached beam (inv 2018), I calculate the flat length should be 412.27in.  I got this by calculating the neutral axis to be at R=262.46in.  I just can't figure how to determine the k-factor for this shape.
IgorMir
Sorry Kirk, I was just following the picture you have posted earlier. 🙂
Interesting solution for the rolled structural elements you have offered. I will keep it in mind.
As for not getting a correct flat length - it might be to the fact that T-Beam is stretching differently then a plate. Just a thought... BTW - what level of accuracy is required? After all - 12" T-beam is not used in super-precise structures. 🙂
Cheers,
Igor.
@karthur1 wrote:
Igor,
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
