curved pattern inventor
huseyinagtas
Message 1 of 16
huseyinagtas
How can I duplicate the marked one so that it is parallel to the surface?
Replies (15)
Message 2 of 16
blandb
Can you post the actual assembly file with all related parts into a zip file instead of a .x_t file? That will just bring in what you have as independent parts.
Autodesk Certified Professional
Message 3 of 16
huseyinagtas
I want to reproduce so that it is parallel to the red surface
Message 4 of 16
CCarreiras
Hi!
Not easy... Here's my attempt...
CCarreiras
Message 5 of 16
blandb
It appears in 2023 that the feature pattern orientation is not adjusting? Unless it is just one of them days for me....
@johnsonshiue
Any ideas?
Message 6 of 16
CCarreiras
HI @blandb , i supposed the pattern orientation (following the line) , only works at 2D level, respecting the source positioning.
The software follows a line, not the surface, (the surface is not an input), and there are millions of different surfaces that could contain that 3D line, how the software knows the one it must follow?!
I believe that is not possible...
CCarreiras
Message 7 of 16
Tom_Sturtevant
Sketch Driven Pattern should be able to do this, adjusting the occurrence orientation based on the normal of the selected reference face(s).  But this requires you to pre-create a (3D) sketch with a point at each occurrence location – and my initial attempt still did not get the occurrence orientation correct…
Tom Sturtevant
Inventor Part Modeling Developer
Autodesk, Inc.
Message 8 of 16
cadman777
Find attached a MBS method. You can do it this way and then 'parts it out' for an assembly. Incidentally, I guessed at the dimensions and configuration you're trying to make b/c I can't read you file.
Although I don't have the method on my version of Inventor, I was going to suggest what @Tom_Sturtevant did, but he beat me to it.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 9 of 16
huseyinagtas
a beautiful road but a long road
inventor should add this type of duplication feature for assemblies
reproduction with curve would be awesome
Message 10 of 16
huseyinagtas
yes it can, but I don't think it will work very well with complex assemblies.
inventor developers should take care of this
Message 11 of 16
cadman777
I agree!
But don't hold your breath!
Here's a quick video on sketch driven patterns in an assembly.
And I'll add that if the sketch driven pattern spacing can't be equation driven, then that should be added too.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 12 of 16
huseyinagtas
yes it will work for simple assemblies
sorry for complex surface mounts but it will be weak
I don't want to compare most cad programs have this feature duplication
It's thought-provoking that he's not inventor
hey inventor, innovate and leave your competitors behind :))
Message 13 of 16
cadman777
Here in America, we call things like 'sketch driven patterns' a 'trinket'.
Others would call it 'foreplay' and nothing more.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 14 of 16
CCarreiras
Hi!
In my long road 😂.... pattern follows the line (the part PR_001012-1-bb has a pattern following the line to create the reference placing points) ... but the question is, it follows the line maintaining the source direction across the line.
Using the method @Tom_Sturtevant and @cadman777 suggested... is a shorter road, and seems to work...
 you just have to use sketch driven pattern.
...Is a good point to ask at Inventor Ideas Forum.
CCarreiras
Message 15 of 16
huseyinagtas
the solution for now is this long road
I hope they add this pattern feature to their next series.
we have high expectations
Message 16 of 16
CCarreiras
I suggest you ask for this in Inventor ideas forum, and link this post... If they don't know the needs, they can't fulfill those needs.
CCarreiras
